Intermittent Passenger Door Lock
Old Jan 30, 2009 | 03:45 PM
4wd150's Avatar
hey everyone. on my 2000 f150, lately i have been hitting unlock to let somebody in my truck and the lock doesnt come up, but then once in a while i get lucky and it unlocks. when it doesnt i can unlock it manually with my key or usually i have to reach across and open it from the inside to let someone in. its getting annoying. any ideas?
Old Feb 8, 2009 | 01:33 PM
blacklab1059's Avatar
Did you ever find a solution? I am having the same problem on my 2000 f150. Thank you.
Old Feb 8, 2009 | 02:17 PM
SSCULLY's Avatar
I would say door lock actuator is on its way out. Some have cleaned them, other just replace them with new ones.
If the door unlocks with the key or the inside handle, that is 90% sure the lock actuator is taking its leave.
Old Feb 10, 2009 | 08:17 PM
4wd150's Avatar
ok thanks alot man! is this an easy thing to replace or what? anyone have tips or pics?
Old Feb 10, 2009 | 09:45 PM
JackandJanet's Avatar
Couldn't it be the interior switch? He says he hits "unlock", and it doesn't work except now and then.
- Jack
Old Feb 10, 2009 | 10:41 PM
SSCULLY's Avatar
- Jack
Guess it could be, nothing is out fo the question on this.
I reacted to :
That could also be an intermittent switch
Old Feb 11, 2009 | 02:49 PM
4wd150's Avatar
the passenger side door lock switch does the same thing as the driver side, it works here and there
