Replacement battery for'05 X-cab Lariat
I agree that the brand doesnt matter much as most batteries are manufactured by Johnson controls, they supply almost all OEM batteries as well as Sears Diehard, Wallmart, and they make the Optima line of batteries.
Go for the most CCA's you can get and most importantly check the fill date if you go with a lead acid battery. The fill date should be punched out of the sticker on top of the battery, if the battery was filled more than 6 months ago keep looking.
