Turn signal/brake light fuse blows
I have a 2000 F150 and the turn signals and brake lights were not working. I narrowed it down to fuse #13. In the manual it is listed as the power to Stop lamp switch (lamps), turn hazard flasher, speed control module. I replaced the fuse and everything worked for about an hour. The next time I went to use the truck the same fuse was blown. Any ideas? A short in the flasher?
I would suspect the MFS switch causing the problem, considering the turn signals, as well as blowing the fuse for the BOO switch together.
When you replace the fuse, do the turn signals work correctly ( until the fuse blows ) ?
Remove the lower part of the steering wheel column and see if the connector under there is pulled apart, and if the MFS connector is still good. Over time these can pull apart, and cause problems, usually in the turn signal function.
If the turn signals worked correctly, I would think a problem with the BOO switch is causing the problem.
2001 EVTM for Stop & Turn lamps ( file save as these for ref )
https://www.f150online.com/galleries...028-169796.jpg
https://www.f150online.com/galleries...028-169795.jpg
Has everyone forgotten about the recall for the leaky SCDS and the trucks going up in flames and that a blown F13 is one of its manifestations?
Search keyword "05S28" - the recall number.
Steve
Steve
Thanks for pointing this out to pinnola, correct diagnoses I should have asked this first even with forgetting the Fuse #13.
CJB fuse #13 feeds both the BPP switch ( EVTM cell 90-3 ) & the deactivation switch ( EVTM cell 31-2 ).
Strange, I am not ASC certified, but I can figure out the EVTM ( with a reminder from Steve ), why can't they ?
hope I can get a replay from this old post! anyways having same issue with a 98 f150 4.2 no cruise, no scds. fuse 13 blows and fuse #1 at central junction box. I have already repaired the wire connection at the multifunction switch as well as replacing the multifunction switch and even the flasher relay. fuses both blow after key is on and either step on brake or use turn signals. chmsl works. PLEASE HELP ME!!!!
00 Ford F150 Fuse 13 keep blowing
I finally found the cause of mine 00 Ford F150 fuse 13 blowing. After checking the brake wiring, brake connectors, flasher/relay connectorand blinker connector by disconnecting each connector and putting in a new fuse to see if it would blow. On the last fuse I ran out of the 20 amp called for in the and used a 25 amp. I found out real quick as soon as I put in the 25 amp where my short was. Under the hood in the drivers corner started smoking alot! Nearly caught my truck on fire but finally found the problem was the crusie control deativation switch. It does have a recall so all i did was disconnect it until I can get it fixed. Now I'm driving around with brake lights and turn signals again! Thanks for you help on here narrowing down what connectors to check!
same problem fuse 13 immediately blows
I got a 2002 F150 my turn, hazards, or brake lights do not work I checked fuses everything, but when I raise my steering wheel my driver side signal work and hazards but still no brakes, I need help ASAP, My number 13 fuse when I replace it my theft light comes on and then the truck won't do nothing, HELP PLEASE..
