Tailgate power lock wiring
Old Jan 2, 2009 | 05:09 PM
James321's Avatar
Ok, searched...results not specific enough. I have a 05 4x4 scab. Purchased a dyno lock. As per instrucions, tried to locate proper colored wires on passenger side. I don't have the wire colors as described in instructions. Can anyone out there with this year truck and who has intalled this device please assist. I have tried to use the pink/orange and pink/green wires that run to my pass-side lock switch, but once I connect the dyno lock wiring, the locks will not even operate my doors. I have also crossed and tried a few combinations of same....help!!!!!!!!!!!!!!
Old Jan 3, 2009 | 09:26 AM
SSCULLY's Avatar
How much more specific do you need ?
The Pink w/ light green stripe is the unlock switch in to the BSM
The pink w/ yellow stripe is the lock switch in to the BSM.
The switch is not tied directly to the door looks like the <=2003 MY trucks, the BSM takes the input, and locks or unlocks the doors with the 2004+ MY trucks.
Depending on when you want the tailgate to unlock is depending on which color.
The BSM has an output for the Driver's front only, which is when you press unlock the 1st time on the Factory RKE ( don't know if you have this installed prior to the remote starter ). Then the second time the unlock button is pressed all the doors unlock. Again, this is factory RKE operation, not sure what operation you have with the code alarm install.
The driver's front door lock actuator is red w/ orange stripe & pink w/ black stripe wires.
The other 3 doors ( or 1 if not a SCrew ) is pink w/ orange stripe & pink w/ black stripe wires.
You will have to check polarity of your tailgate actuator, but it seems when pos is on pink w/ black stripe wire, this is lock.
Search for Tailgate, power, lock in this forum, showed up as the 2nd thread ( yours was first ).
https://www.f150online.com/forums/el...e-color-q.html
Old Jan 3, 2009 | 01:09 PM
James321's Avatar
Thanks....must have missed that one.....
