How do you check a relay?
Old Jan 3, 2009 | 11:47 AM
Blang's Avatar
How do you check if a relay is bad? Is there anyway to check without just replacing?
Old Jan 3, 2009 | 12:11 PM
SSCULLY's Avatar
If it is a full ISO relay, apply power and ground to the coil ( pins 85 & 86 ).
Measure the resistance over the Normally closed contacts ( 30 & 87 ), this should be 0 or close to it.
When you remove the power from the coil, the resistance should go to infinity.
Sample drawing :
If it is a Ford half ISO, the numbers change for the assignments, but the function is the same
Old Jan 3, 2009 | 12:49 PM
mattd17's Avatar
wow SSCULLY, your awesome at these relays...... you helped me a bit the other day too!
Old Jan 3, 2009 | 01:33 PM
SSCULLY's Avatar
Don't thank me until you find one that costs less then that Square D JCK type. Those are USD$ 100.00 + each !!
Elk might have them in the 30.00 range, and you would need to buy a small plastic enclosure for it ( usually bare, made for putting into a security cabinet ).
