Tach/Cluster Help?
Old Dec 31, 2008 | 02:25 PM
Raptor05121's Avatar
Tach/Cluster Help?
So I pulled a cluster from a 1997-1998 F-150 XLT with the tach on it. My truck dosent come with one, so this is a must since my truck is a stick shift.
I know the plastic is broken. When I swap them out I'll pull the one from my current cluster and put it on this new one.
Problem #1: How do I spin the odometer to display my current mileage? This pulled one has 121,538 while mine has currently 168,835 miles.
Thanks in advance!!!
-Alex
Old Dec 31, 2008 | 09:40 PM
Bump
Old Dec 31, 2008 | 10:26 PM
02SC4x4's Avatar
try these posts
https://www.f150online.com/forums/el...ster-swap.html
-note the 2nd post where you might need to add a wire
https://www.f150online.com/forums/el...-question.html
-note the 2nd post where it need to be DEALER programmed.
a search with the terms "cluster swap" will yield you more results
Old Dec 31, 2008 | 10:39 PM
The dealer programming is for the 99+ years with the PATS and a digital readout. If you look at the one I pulled, it has an analog readout.
