Airbag Light
Old Dec 17, 2008 | 05:15 PM
TylerFX4's Avatar
Airbag Light
i have a 03 fx4 my airbag light came on about a month ago and i cant figure out why any advice?
Old Dec 17, 2008 | 07:29 PM
02SC4x4's Avatar
you need to count the flashes and give us the code, it should be something like 2 flash, pause, 5 flash, then it repeats it 2 more times, then goes on solid.
Old Dec 22, 2008 | 04:18 PM
TylerFX4's Avatar
it goes 2 flash, pause 7 flash
Old Dec 22, 2008 | 08:12 PM
SIK-06's Avatar
Have you taken the dash apart recently. Mine did that because i didnt plug the air bag light wire harness back in all the way. i know you have a different year i just thought i would throw that out there i case i triggers any thing in your head..
Old Dec 22, 2008 | 08:26 PM
SSCULLY's Avatar
From search for [/i]airbag 27[/i] the threads indicate this is a passenger side airbag light is burnt out. Some threads here on replacing this, with a bulb from Radioshack.
https://www.f150online.com/forums/el...code-27-a.html
The bulb out condition can be simulated on the 04+ MY trucks by not plugging the connector back in ( bulb not there, not filament in the bulb ).
Old Dec 25, 2008 | 12:31 PM
TylerFX4's Avatar
ill try that thanks for the help
