compass and thermometer not working
Old Dec 22, 2008 | 03:13 PM
castroc4's Avatar
Post compass and thermometer not working
my compass and thermometer stopped working recently and i have no clue what is wrong with it. i was reading other posts and they said that the circuit board most likely has a loose chip. i looked at it and i found nothing loose or missing. any ideas????
Old Dec 23, 2008 | 06:54 PM
4play2008's Avatar
it's really hard to see and sometimes you cant. you can try to re-heat the connections but if no luck you will probabl need a new one or a used one from the wrekers
Old Dec 24, 2008 | 01:37 PM
Tschro's Avatar
I also have a compass /temp light problem. Has anyone had the display work intermitently? lately, when I start my truck the compass/templight won't come on automatically. I have to toggle the switch. If I do it enough times it will usually start to work. only to not work again at startup. Anny suggestions?
Old Dec 24, 2008 | 01:49 PM
crash_lucky13's Avatar
same here...except mine has only started working ONCE in the last year... can't figure it out...
Old Dec 25, 2008 | 11:26 PM
4play2008's Avatar
mine did that too i just hit it and it worked..... but after a few months it just went dark.
