window switch dead...can I remove the cluster surround?
Old Dec 15, 2008 | 12:29 PM
dalman's Avatar
It is super cold (-25 c) and I am driving around like a moron with my window 3" open 'cause it won't roll up!:o Is there a way to pop off the panel surround of the switch cluster on the drivers side without taking apart the whole door....and popping the switch out and cleaning the contacts or replacing the switch?
And, The LED is out on the door lock switch...same deal, can I replace the light or is it a whole switch?
BTW 04 Screw Lariat
Old Dec 15, 2008 | 01:45 PM
SSCULLY's Avatar
Pop the speaker cover off ( clips around the edges ).
The switch cover now pops up from the inside ( towards where you sit ) tabs are under the door handle part of the cover ).
You can use a plastic trim tool, or if you are VERY CAREFUL, a 1" putty knife covered in a rag ( PITA bit wide, and you need to taek it slow, else scratch city )
Old Dec 15, 2008 | 01:55 PM
dalman's Avatar
thanks..I will warm it up too before I try....the power door lock switch...is the light part of the rocker switch or is it separate (can I remove/replace the switch and get my light back?)
Old Dec 15, 2008 | 02:33 PM
JackandJanet's Avatar
SSCULLY - forgive me for doubting you, but I had to take off all my inside door panels when I installed Jimi-Jammers and I'm pretty sure you can get the switch cover off the armrest without messing with the speaker cover. I think it just prys up off the armrest, and once it's up, you can disconnect all wiring to the switches. It's possible, though, you have to remove the door handle first (hidden screw behind a small access plate behind the handle) to get clearance for the cover to lift up.
My Haynes manual shows this to be the step right BEFORE removing the speaker covers when you remove the door panel too.
As I recall, I did the prying with a plastic putty knife.
- Jack
Last edited by JackandJanet; Dec 15, 2008 at 02:40 PM. Reason: Added thought about removing door handle
Old Dec 15, 2008 | 02:44 PM
dalman's Avatar
that's the order I read about in the muthco website (instructions how to remove door panels)...speaker after the switch surround.....
Old Dec 15, 2008 | 02:55 PM
SSCULLY's Avatar
Speaker grille 1st, then switch, The speaker surround covers the edge of the switch, at least it does on my 2006
Old Dec 15, 2008 | 02:57 PM
SSCULLY's Avatar
- Jack
I actually did this just before posting to the thread on my 2006, to make sure I had the order correct. 2004 could be different door panel though...
Done in this order, the switch panel popped right up
Steve
Old Dec 15, 2008 | 03:04 PM
dalman's Avatar
thanks for the tips guys..can I ask about the power lock switch (I thought I would tackle that once I had the cover off anyway.....is the light part of the switch?
Old Dec 15, 2008 | 04:58 PM
Steve
Interesting Steve. I see now how this might work on mine too (but I'm not going to pull the speaker cover off just to test it). I suspect we ALL have the same door panels.
And dalman, sorry, I don't know for sure if the light is part of the switch or not. However, I seem to remember reading on the appearance forum that it's a tiny light inside the switch. This was in response to a post wondering about replacing all those lights with LEDs.
- Jack
Last edited by JackandJanet; Dec 15, 2008 at 05:01 PM. Reason: Added response to dalman
Old Dec 15, 2008 | 05:09 PM
SSCULLY's Avatar
Yes, there are a few threads on here about the topic ( as well as changing the LEDs to a different color ).
Considering the cost of a new switch, might not be worth the runnign around
https://www.f150online.com/forums/20...ck-lights.html
