Blown Fuse after fog light mod??? Should I be worried???
Old Sep 7, 2008 | 11:50 AM
speedstang's Avatar
I did the fog light mod and everything works like it should. Fogs come on with park lights and stay on with high beams. Except the #27 fuse under the dash keeps blowing. In the manual it says Foglamp Relay and Foglamp Indicator, Main Light Switch (upstream). With the fuse blown it doesn't seem to affect anything. Should I be worried?????
Another thing...My dome light works when you open the door, but after it shuts off and I try turning it on by the dimmer switch, nothing happens. I did blow a fuse in the engine bay while doing the fog light mod because I tied into the wrong wire. I lost interior lights and park lights. After replacing the fuse, the lights work fine. When I did tie into the wrong wire, I did see a little smoke coming from the headlight switch assembly. I quickly turned off the lights and disconnected the wire. Not sure what it could be. Any help would be appreciated. Thanks
Old Sep 7, 2008 | 03:18 PM
SSCULLY's Avatar
here is what the wiring should look like after doing the wiring change and ramp modification on the 00-03 MY trucks
I don't recall if this is in the directions, but that fuse should be removed, it is not longer needed.
Old Sep 7, 2008 | 04:17 PM
speedstang's Avatar
Thanks for the reply.....What about my dome light working when the door opens, but not turning on with the dimmer switch??? Any ideas??? I check all the fuses..
Old Sep 7, 2008 | 05:57 PM
Rockpick's Avatar
Moderator &
Sorry, speed... I'm not the guy that's going to be able to help with this one... SSCULLY is my resident expert for electrical help... Good luck, bud. Sorry.
Old Sep 7, 2008 | 09:45 PM
speedstang's Avatar
Thanks rock for getting back to me....anyone else have any ideas why my dome light wont turn on with the dimmer????
Old Sep 8, 2008 | 08:59 AM
SSCULLY's Avatar
Well, let's see :
...<snip>...When I did tie into the wrong wire, I did see a little smoke coming from the headlight switch assembly. I quickly turned off the lights and disconnected the wire. Not sure what it could be....<snip>...
Everything electrical runs on magic smoke, and once you release the magic smoke, they stop working...
In all seriousness, sounds like you smoked the solid state dimmer switch.
Old Sep 8, 2008 | 05:16 PM
speedstang's Avatar
Ya I now, I am retard for hooking into the wrong wire....But the dimmer switch will still lower and brighten the dash lights, but when clicked all the way up, no dome light....What do I have to do to fix it??? New headlight switch assembly???
