2002 f150 Instrument Cluster Panel won't turn on... Help me Please.
Hi all,
I have a 2002 f150 supercab...I am having a problem with the instrument cluster panel not illuminating (usually they illuminate when I turned on my head lights). I checked the fuse that runs the cluster panel thinking it was the problem and changed it a few times...But the fuse kept blowing out. Can you please help me with my problem... THanks in advance! -KARL-
you only specified the cluster not illuminating. can i assume from this that your headlights do come on and stay on?
if that is the case and your headlights illuminate while the cluster does not, i would suspect the dimmer switch. try disconnecting the dimmer switch from the harness and seeing if the problem still occurs. and while your in there you may want to check from worn out/cracked/rubbing wires that could be causing the problem.
