"BRAKE" light no longer engaging
Old Aug 24, 2008 | 08:57 PM
Raptor05121's Avatar
When I press my emergency brake all the way down, the red "BRAKE" light is no longer lighting up. Is it a sensor or a simple bulb? I hope its a bulb, that way I can fix my odometer cable and replace all those lights with LEDs at the same time.
Old Aug 24, 2008 | 09:09 PM
projectSHO89's Avatar
The red BRAKE light should come during initial bulb prove-out when starting the truck. If not, it is probably the bulb.
If the bulb proves out but does not light when the e-brake is set, then the switch on the e-brake assembly is out of adjustment or has failed.
Steve
Old Aug 24, 2008 | 09:11 PM
thanks, ill go start her up and see.
Old Aug 24, 2008 | 09:21 PM
false alarm. its working now. i took it for a ride and it seems that you have to do a quick full depress for it to light up. it wont light up if you slowly depress it. oh well. thanks
Old Aug 24, 2008 | 09:39 PM
mark razmandi's Avatar
wait i have that problem too...sometimes when i engage my e-brake it comes on and sometimes it doesnt.....i never really gave it much thought....what could it be besides a bulb?
Old Aug 24, 2008 | 09:54 PM
The switch is probably sticky.
Steve
Old Aug 25, 2008 | 02:26 AM
oh alright...thanks
