Starter Issues
Starter Issues
I have a 1997 F150 that I've been trying to get started for a while now. We tried jumping the relay that's under the hood, but to no avail. So I got under the truck to check the connections to the starter, and the one connection that runs straight from a stud to the back of the starter (looks like a ground strap) was so corroded that as soon as I touched it it fell apart. Is there some type of kit I can buy to replace that part? It was attached to one of the studs with a screw, so I assume so.
Thanks!
LiquidOC
Thanks!
LiquidOC
Could you make a replacement strap with a piece of flattened copper pipe?
I had problems with the starter on my '97 f510 as well. The battery cable broke off at the starter, had to solder a new lug on the end. Then the housing corroded so badly that it would not ground to the block anymore. Wire-brushing the starter housing and mating surface on the motor fixed that. The original starter was still on it after 9 years when I traded it in.
Good Luck
Walt
Good Luck
Walt
