help power sliding rear window
Old Jun 4, 2008 | 03:42 PM
gbento's Avatar
Question help power sliding rear window
I want to install power sliding rear window, wanted to know if an 01 f150 harley davidson supercrew was prewired
Old Jun 5, 2008 | 02:28 AM
minimonster17's Avatar
it may or may not have been. it seems pretty haphazard in these trucks as to what's prewired, and what's not. as far as where to check, pull off the dash bezel that covers the headlamp and instrument cluster. look where the button would go for the windshield if it were there. there should be two sections of wire plugged off w/ a plastic grommet. one is to the the adj pedals, and one is for the power windshield. the one to the windshield is further off to the right, while the wiring for the pedals button should be in plain view. if you have the adj. pedals, chances are its wired, but look anyway. if you have the section of wire plugged up for the windshield, you are prewired for it.
Old Jun 5, 2008 | 08:36 AM
SSCULLY's Avatar
I just took a look when RP did his power rear slider in his '01 KR, and that was not pre wired.
https://www.f150online.com/forums/sh...d.php?t=105776
If you sort the electrical forum by replies, RP has the top 3 reply threads in this forum. Not bad for a guy that is not electrical by his own admission
Old Jun 5, 2008 | 01:28 PM
gbento's Avatar
Smile power slider
Thanx for response I will check and let you know , I do have power pedals
