Headlights
Old Mar 24, 2008 | 09:35 PM
Tinman66's Avatar
Headlights
Question: I installed a leveling kit on my F150 and of course I never measured the height for adjustments so that my headlights do not shine in the back of peoples heads. Is there any height/measurement for the headlights where they are to be adjusted too? Not sure if there is a DOT regulation on height. Any help would be appreciated.
Old Mar 24, 2008 | 11:47 PM
JackandJanet's Avatar
There's alll kinds of complicated ways of setting the headlights assuming you are on a level surface and are just exactly (25 ft?) from a wall.
My approach is to go out to a nice, level, deserted road at night and adjust those things so they light up where you are going and not the sky or the ground right in front of your truck. I bet if you do this, your lights will be aimed right.
- Jack
Old Mar 24, 2008 | 11:49 PM
OrdnanceCorps's Avatar
My headlights need adjusting, but working with fords way its frustrating with those friggin tryin to get the headlight to fit right after adjustment.
Old Mar 25, 2008 | 01:21 AM
Grubrunner's Avatar
http://www.s-10crewcab.com/og1/modin...specs/aimh.htm
