Wiring Toggle switch into DRL
Old Feb 24, 2008 | 02:58 PM
caper28's Avatar
Question Wiring Toggle switch into DRL
I have a 2006 F150 XLT super cab and would like to wire a toggle switch into the DRL so I can turn them off when needed. Has anyone done this?
Old Feb 24, 2008 | 03:31 PM
joshmac4.6's Avatar
Haven't done this but I can which wire to put the switch in. There is wire, its black w/red tacer that comes out of the Aux. relay box, that would be the wire to put the switch in.
Old Feb 24, 2008 | 03:36 PM
caper28's Avatar
I heard it could be done. Wasn't quite shure which wire though.
Old Feb 24, 2008 | 08:51 PM
caper28's Avatar
Was out checking the aux relay box. There's no black/red wire. Was thinking of pulling the relay and testing the wires to find which one is for the DRL (should be hot with the relay in and not hot with it out) then wiring a switch to that one. Will this work?
Old Feb 24, 2008 | 09:17 PM
joshmac4.6's Avatar
Ok, well how about a orange w/ light green tracer. It shows it coming out of aux. relay box 1 and it goes to the drl resistor which is located behind the left front headlight.
Old Feb 24, 2008 | 10:42 PM
caper28's Avatar
That one I do have, hard to see exactly where it goes. A little too dark right now. Goes down under the headlight.
Thanks alot
Old Feb 24, 2008 | 10:48 PM
joshmac4.6's Avatar
Thanks alot
Well best I can tell from the diagram, a switch in that wire will give you the ability to control the DRL's.
