Train horn power?
Old Feb 6, 2008 | 08:33 PM
bigdad8214's Avatar
Train horn power?
I want to put my compressor behind the rear seat "Crew cab" and I don't want to run a power wire all that way. What do you guys think about splicing off the trailer power supply? That way the pump will only come on with the key so I don't have to run another relay. It should handle it, it does run all the lights and stuff in the trailer.....
Old Feb 6, 2008 | 11:11 PM
97f1fifty's Avatar
I have the compressor behind my seat, which my truck is a Single Cab but it really isnt all that bad running the wire the only problem is what you mentioned it does run constantly and my tank has a leak now if i leave it pluged up it will run my battery down..
Old Feb 6, 2008 | 11:53 PM
alsupercab's Avatar
got a tool box? Id be mounting it in there if so
Old Feb 7, 2008 | 08:06 PM
bigdad8214's Avatar
Not really a tool box guy, don't want a bunch of junk getting in there. And that is just what will happen......
Old Feb 14, 2008 | 12:49 AM
scavenger11's Avatar
Cool
if i were you i would hook it up to a toggle switch and then run it straight to the battery, that way you can choose when you need it on.
just thought i would throw that out there
