Colored LED's in the dash?
Old Jan 25, 2008 | 11:31 PM
Raptor05121's Avatar
Noticed today that some parts of my dash are faded (fuel gauge line is dimmer and others) and I was thinking of getting some wide-angled blue LED's to replace the lights with. They should be powerful enough to cancel out the "greenish" tint Ford put on the gauges. What do you guys think?
Old Jan 26, 2008 | 12:48 AM
roushstage2's Avatar
I think it will be tealish. That tinted plastic holds it's color pretty well. If it did work, I think it would be so bright you wouldn't want them in there.
Just buy a blue colored overlay?
Old Jan 26, 2008 | 07:33 AM
Grafix Ink.'s Avatar
do it...
100% wrong.
i have seen people do it with green leds to make it 'true green' and blue leds to make it 'blue.
and no, its not overpowering at all and not tealish any longer.
in fact i am doing the same thing to match my deck... all wide angle leds
Old Jan 26, 2008 | 09:28 PM
Originally Posted by Grafix Ink.
100% wrong.
My bad!?
I've tried it on a couple other vehicles with the same factory green tint deal and it did not work. Became "tealish." At least it works on something!
Old Jan 26, 2008 | 11:45 PM
Any good recommendations for types, Grafix? Are the wide-angled ones the ones with bulbs all around and facing front? I got my LED dome from Oznium today. Install was a b!tc% but looks good. The inside of my cab is bright as day now! 5/5!!!!
Old Jan 27, 2008 | 09:10 AM
types? i would just get wide angle wedge 194's and wide angle 73's or 7'4s i think...
you can get other ones and try if they fit.. but the ones with multiple leds are wider / longer then the wide angle ones.. thus migt not fit into the hole
Old Feb 1, 2008 | 05:41 PM
Jshera's Avatar
http://www.sn95forums.com/forum/index.php?topic=19730.0
Heres A how to on a mustang. It also mentions that the standard dash with green numbers will light up blue when you use a cool white(blueish tinge) LED.
I allready order my leds for the dash and HVAC and I will post up a little how to.
Old Feb 1, 2008 | 07:32 PM
its as straight forward as replacing your bulbs with led replacements. not much needed for how to for this one.
i would suggest trying wideangle leds as well.. as the ones shown in link might not fit the hole...
ordered mine a few days ago..
Old Feb 14, 2008 | 12:58 AM
scavenger11's Avatar
if you take out your gauges and use nail polish remover you can take the green off and it would be clear.
