Help with back up lights
Old Feb 3, 2008 | 07:29 PM
mc2912's Avatar
Question Help with back up lights
picked up some hellas 550's and i wanna add them as back up lights. to turn on when i put in reverse. can some one help me with the wiring diagram??
Summary of the wiring diagram.
Option #1
1. Red - Power to Relay
2. Black - Relay to Lamps
3. Blue - Relay to Low Beam tap
4. Green - Parking Lamp tap to rocker switch
5. Yellow - Rocker switch to relay
Option #2
3. Blue - Relay to Ground
they way i think it would go
2. Black - Lamps to Relay
3. Blue - Reverse Tap to Relay
page 2 on here
http://www.hella.com/produktion/Hell...structions.pdf
Old Feb 3, 2008 | 08:11 PM
2006M50B's Avatar
2. Black - Relay to lamps
4. Green - Reverse light tap to rocker switch
This is the same way my hella 500's are wired up-only differance is I have the parking lamp as lead instead of the reverse light
The only time you would hook the blue ground wire from the relay to another lead such as the low or high beam is if there is a ground problem and the lights come on with any light being on, or something like that. Hook the blue wire to ground and you should be set.
Old Feb 4, 2008 | 02:15 AM
mc2912's Avatar
so with the green going from the reverse light tap to the rocker switch i will be able to turn the lights on with out it the truck being in reverse right? one more question.... will i be able to turn the new lights off while on reverse if i wanted to?
Old Feb 8, 2008 | 02:33 AM
mc2912's Avatar
bump
Old Feb 8, 2008 | 10:28 AM
subford's Avatar
Is this what you are looking for?
Old Feb 8, 2008 | 07:01 PM
2006M50B's Avatar
Ok i must have misunderstood what you wanted the first time, if you want to be able to turn the lights on/ off as you please you should be able to run the green wire to the battery (put a fuse on the line-something small like 1 amp or if that is to small maybe a 5 amp) or you can run to parking light lead but if you do that the backup lights will only work if you have your parking lights on
Old Feb 13, 2008 | 10:42 PM
mc2912's Avatar
Some progress.. no wiring yet
Still needs to be painted....
Old Feb 13, 2008 | 10:46 PM
mc2912's Avatar
Are they too big??
Old Feb 13, 2008 | 11:04 PM
alsupercab's Avatar
nice detail work and I dont think they are too big.
