door locks
Old Jan 29, 2008 | 09:51 PM
00fordman16's Avatar
door locks
ok a couple of months ago i bought a 2000 f 150 7700 supercab 4x4. When i start the ignition the doors lock automatically.Is this a type of aftermarket system or what? Would it be hard to change back to a stock setup? What is approxmate dealer charge for that?
Old Jan 30, 2008 | 06:56 AM
torkum's Avatar
When you say start, do you mean when you put the truck in gear? If they lock when you put the truck in gear its factory and you can disable that.
Old Jan 30, 2008 | 08:17 AM
02SC4x4's Avatar
i think their suppose to lock @ 5mph or something like that.
Old Jan 30, 2008 | 09:45 AM
no as soon as i turn the key over and it starts the doors lock and sometimes when i hit the unlock from the drivers side the passenger tab on the inside doesnt go all the the way up causing the passenger on the outside not to be able to get in
Old Feb 2, 2008 | 09:47 PM
Pinhead-227's Avatar
My '99 5.4L 4x4 does the same thing. As soon as the key is turned, the doors lock. They unlock automatically when the ignition is shut off. I wouldn't mind it if it shut off when you go over 5mph, but the way it is you have to worry about starting the pickup to check the transmission fluid, etc and having the keys locked in the pickup with the engine running. Not fun. How do you disable the system?
Old Feb 2, 2008 | 10:24 PM
M4Madness's Avatar
My '99 is the same way.
Old Feb 14, 2008 | 09:41 PM
i have the pats system if this helps and how hard is it to get a keyless entry maybe i have a factory one because i have a miniature pamplet on factory keyless entry in the owners manual just a thought thanks Basile
Old Feb 26, 2008 | 07:17 PM
M4Madness's Avatar
Those of you with the doors that lock as soon as the ignition is turned on probably have a dealer-installed aftermarket system. I found out today that that's what mine is:
https://www.f150online.com/forums/sh...d.php?t=322078
Old Feb 27, 2008 | 03:54 PM
Deactivating/activating the autolock feature
Before following the procedure, make sure that the igntion is OFF and all vehicle doors and the liftgate window are closed.
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to RUN.
2. Press the power door unlock control three times.
3. Turn the ignition key from RUN to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to RUN. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will chirp once if the autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Old Mar 6, 2008 | 08:23 PM
m4 madness, i have the same module as the one you have shown up above in your link. Is there a way to get key fobs for the aftermarket version put on by the dealer at the dealer?
Old Mar 7, 2008 | 05:37 PM
M4Madness's Avatar
Yes. You'll need to call 1-800-FORD-KEY and provide them with the little number in the corner of the sticker on the box to get the Ford part number for the remote. The number on mine was "Z-9", and is probably the same as yours. The Ford Part number for the remote is F7AZ-15K601-AB, and dealer cost is $52 each. If yours has "Z-9" on it, then you can skip calling the phone number above, and just have your dealer order the remote(s).
EDIT: Here's one I just located online:
http://expresslinkss.com/southland/c...rtOrder%3DDESC
