Keypad problem
Old Aug 21, 2007 | 09:00 PM
bfausett84's Avatar
Keypad problem
When I press 0 on my keypad to lock the doors, the lights come on, and the light on the keypad comes on, but the doors do not lock. I don't know the code to unlock the doors since i bought the vehicle used and they only had one key and now key fobs for the vehicle. I don't know what could possibly be causing the problem and the chiltons i bought doesn't even mention the door keypad. Help?
Old Aug 22, 2007 | 07:57 AM
usnzulz's Avatar
Keypad
If you look up under the dash on the drivers side you will find the module for the keypad it has the code printed on a sticker it is right by the parking brake as for locking the doors you push the 7/8 9/0 key together at the same time that locks your doors if you have your owners manual it will tell you how to set a personal code to open your doors but you have to know the factory code to set a new code you can get a key fob on ebay for cheap and programming is easy on and off 8 times doors lock and unlock hit a button on each remote you want to program hope this helps.
Old Aug 22, 2007 | 11:51 AM
SSCULLY's Avatar
The location for the code ( on the RAP/CSM for 99-03 + 04 Heritage & L and on the BSM/VSM for the 04-present ) is depending on which MY truck, and body style you have.
Under the dash as usnzulz posted, is only for the 99-03 body style. If you have a 04+ MY truck, the BSM/VSM is on the rear cab wall in one of 2 places.
As for the single key, you will need a PATS locksmith ( if your truck is a 99 - present ) , or a dealer to get a 2nd key programmed. 2 PATS programmed keys are needed to add any additional keys. Best to have at least 1 new key cut, and have the HEC erased and reprogrammed, so the other key(s) are removed ( procedure for this in the service manual ).
If you are at a dealer for adding a key, you might be able to have them get the code ( if you have a 04+ ) for no extra charge ( maybe, you would need to ask ), so you don't need to remove the rear seat back. Again this is a '04+ MY item, and you do not have any truck information posted, or completed in your profile.
To program RKE remotes purchased somewhere else ( other then the dealer ) :https://www.f150online.com/galleries...028-194194.jpg
Need to program all remotes at the same time. The enetering programming mode erases the previous stored ones.
Old Aug 22, 2007 | 03:35 PM
bfausett84's Avatar
Thanks guys, this helped a lot, i went by a dealer today and he came out and got the factory code and put in a personal code and i'm going back to get another key and 2 remotes. Thanks so much again.
