Electrochromatic mirror
Old Apr 3, 2007 | 01:36 PM
Nutdriver's Avatar
Hi all:
Does anyone know how to recal. the compass on the Ford Electrochromatic mirror? My temp works and the auto dim works but the compass does not read so Im thinking it needs a reboot. Any help would be appreciated.
Old Apr 3, 2007 | 01:57 PM
06 So Comfort's Avatar
Originally Posted by Nutdriver
Hi all:
I believe all you have to do to calibrate the compass is find an open area, away from overhead wires or metal structures, and drive in a circle for a couple loops.
Old Apr 3, 2007 | 02:08 PM
SSCULLY's Avatar
The '99 owners manuals are really for crap, search for compass turned up nothing ( as in, the OM says it is not in there ?? )
One thing you can try is to download a 2001 Owners Manual, and try the procedure listed starting on page 56
https://www.fleet.ford.com/maintenan...ls/default.asp
This is press & hold the select button until CAL shows in the display, before driving in circles. Watch your speed, they are not kidding when they say les then 3 MPH. Any faster, and you will just get dizzy ( won't calibrate )
Worth a try to press and hold the Select button to see if CAL shows up in the display ???
Old Apr 3, 2007 | 08:24 PM
Steve83's Avatar
The procedure is the same as for the overhead console, which is described in this thread. For vehicles with the compass in the instrument cluster, you still use the reset button on the mirror. It's just harder to find.
Old Apr 4, 2007 | 02:15 PM
Bluegrass's Avatar
The cars from the late 80s use the same compass calibration procedure and include an offset for the part of the country you live in by asking for an entry number corasponding to your location from a map that should be provided in your book.
The only differences thru the years is how you access the calibration controls.
Old Apr 9, 2007 | 05:58 PM
Nutdriver's Avatar
Hi all:
Thanks for the speedy reply's. I tried the recal as you guys described but I think I may have a problem with the mirror itself. As i cant get it to go into cal mode and all that shows on the display is a bunch of garbage. I tried to add a picture of what I get and if anyone has seen this displayed before maybe they can point me in the right direction.
Thanks again
http://www.kodakgallery.com/BrowsePh...id=0&ownerid=0
Old Apr 10, 2007 | 11:57 AM
Steve83's Avatar
That link doesn't work. I suggest you upload your pics to SuperMotors - it's free, and it provides the text needed to embed an image into this type of BBS.
Old Apr 10, 2007 | 12:40 PM
SSCULLY's Avatar
Another option for a gallery is right here on F150online
https://www.f150online.com/galleries/new.cfm
Tried that Kodak URL, and got the login page ??
Old May 2, 2007 | 11:21 PM
Nutdriver's Avatar
Thanks for the info guys been away for few days. Try this link:
https://www.f150online.com/galleries....cfm?gnum=9752
Any help appreciated. p.s. This sight is awesome! Just found a fix for my odometer intermitant trouble. Thanks again
Old May 3, 2007 | 02:14 PM
Steve83's Avatar
If you right-click any image, you should get a context menu with "Properties" at the bottom. Click that, then triple-click the URL text to select all of it. Hit Ctrl+C to copy it. Then, in your post here, click the image icon (yellow w/mountain & sun) & hit Ctrl+V to paste the URL into the dialogue box, then ENTER & it'll remote-link the image into your post, like this:
If that's all it ever shows, it appears to be fried.
