Stopped 2006 F150 ODOMETER
Old Apr 5, 2007 | 03:50 PM
SSCULLY's Avatar
Originally Posted by fdn_ford_83
Whent he fuse is taken out the odometer does not rack up, when put back in the odometer is the same as it was before you took it out. Even after the truck has been driven 100miles no mileage change. So where exactally does the mileage record at. I mean it must be right at the odometer in the instrument panel. Other wise wouldn't the brain update the odometer once the fuse is replace? explainthis to me?!
Reporting thread to a moderator -> asking about committing fraud.
You seem to be playing around with something, claiming a blown fuse. That is fraud, and against the forum rules.
Hope you never have to have your truck plugged into a WDS / IDS unit at a dealer. You are going to be in for it.
Old Apr 14, 2007 | 01:26 PM
mikedice's Avatar
Hey when you trade them in they usually only look at the dash milage anyhow!!
Old Apr 14, 2007 | 02:16 PM
modman2k5's Avatar
i second that man...i dont know if you know that you can get jail time for something like this...its serious compared to illegal cat removal which is only a ticket...odometer tampering is a federal offense...and if anyone ever puts 2+2 together when they sync your car at ford or somewhere they will report you because im sure its in the cars memory
Old Apr 15, 2007 | 12:54 AM
bigrook99's Avatar
You probably still rent VHS movies and dont rewind them either.
Old Apr 26, 2007 | 02:08 PM
gumbyone's Avatar
Reverse
No you dont need to replace the fuse. Its up to you, now having said that all you have to do it jack up the truck with the fuse out and run it in reverse for a while. This will indo all the extra miles.. .
DAve
Old Apr 26, 2007 | 08:15 PM
dreamsr's Avatar
Cool
ROTFFL!!!!
Good one gumbyone. If he wants to tamper with his "beauty" then I say let him do that... All on his own!
