Cruise Control
Old Mar 26, 2007 | 03:31 PM
shelbysdk's Avatar
Cruise Control
I have a 1995 F-150 5.0L and the cruise control does not work.I first checked the fuse, then I took the steering column apart and tested the switches, which were all good. Then I proceeded to check the cruise control servo under the hood. The wiring harness coming into the servo gets a signal when the buttons are pushed. I am not sure how to check the speed control and the servo itself. Also are there any other possibilities that it could be??
Old Mar 26, 2007 | 05:44 PM
Steve83's Avatar
Have you had the recall done? Is there any liquid inside the switch on the master cylinder?
If that's OK, follow this diagnostic, referring to this album.
Old Apr 11, 2007 | 12:36 PM
shelbysdk's Avatar
found to be the servo, the diagrams and charts helped alot thanks
