Theft light always blinking
I have a 2002 F-150. Until this morning I never noticed that the theft light blinks continuously after turning the engine off and removing the key. Is it supposed to blink all the time? I called the service department at the dealer and the guy I talked to said he didn't think it was supposed to. Anyone know the correct behavior?
Thanks...
Thanks...
on
Ref owners manual starting on page 112 :
The theft indicator is located on top of the instrument panel.
- When the ignition is in the OFF position, the indicator will flash once every 2 seconds to indicate the SecuriLocky system is functioning as a theft deterrent.
- When the ignition is in the ON position, the indicator will glow for 3 seconds to indicate normal system functionality.
If a problem occurs with the SecuriLocky system, the indicator will flash rapidly or glow steadily when the ignition is in the ON position. If this occurs, the vehicle should be taken to an authorized dealer for service.
