HID kit
Old Feb 2, 2007 | 12:24 PM
iziris's Avatar
HID kit
As i was reading some threads i noticed a few people saying that vehicles with HID have a specific headlight due to the scattering of the light. Would it not be wise to put a HID kit on a 97 f150? is there a certain aftermarket headlight i should buy to correct this problem?
Old Feb 2, 2007 | 01:19 PM
2stroked's Avatar
What you want to avoid is simply replacing your current 9007 Halogen bulbs with HID bulbs. That's where all of the problems come from. Your current headlight housing / reflector / lens is simply not designed for that type of bulb.
If you replace your headlight system with something like the Sylvania Xenarc system - which replaces the whole housing, lens and bulb you - and everybody coming the other way - will be much happier. The Xenarc system is designed as a complete system. That's why it works. Of course they no longer offer that system ...
Old Feb 2, 2007 | 02:25 PM
iziris's Avatar
So are you saying there are no other kits or is that one just an example?
Old Mar 16, 2007 | 09:12 PM
Bunthy's Avatar
just following up,
if you do put a HID kit int eh stock housing, its fine. beam pattern remains the same. Trust me, I've tried the projector [h3 hid], HID 9007 in the clear housing and all of them ruin the beam pattern, but not the OEM housing. I just don't like the composite housign look.
