How to dismantle Ignition switch
Iam trying to fix a problem with a F150 4.2 L 2001 year model.,
when the car is running and i engage the Trany in N or P the Starter kicks in and the lound noise screeching noise, and when the Key is out it keeps beeping , and as a matter of fact the radio when iam driving powers onn and off., except on low volume.
i thought it was some Trany issue, but guys in this forum told me no its not, its the Ignition switch or linkage.
I took off the switch under the coloum and took it apart , its working fine., however, i cant figure out how to take apart the unit where you insert the Key ., I feel there is problems there, because i have the play with it when i take the key off to stop the beep., and i need to fix the starter issue too.
so is there a (how to guide somewhere to do this).??
sincerely matt
sincerely matt
on
Are you looking for how to remove it from the steering wheel column itself ?
https://www.f150online.com/forums/sh...light=ignition
Or are you asking about how to take apart the ign switch, already removed from the streering wheel column ? ( that one I could not find a thread on ).
JMC's instructions in the thread work great for removing the ign switch, to take out the key in ign chime ( did it on my dad's '01 ).
Thank you for responding.
Iam trying to take off from steering , to fix , or change the sensors right there, the plastic cover where the Hazard switch is cant be removed., so i need to remove the Black switch unit where the key is put.
and of course i would need to see if the linkage is ok, ...etc, some wire is broken i found, so indeed i need to get that thing out and maybe apart.,
sincerely
sincerely
