1992 Interior light issues...HELP!!
Old Dec 30, 2006 | 01:30 PM
atsirois's Avatar
Hey guys,
I've read through the thread about the dome lights, but my seems to be different...the symptoms are the same, but it's on an older truck, a 1992. The dome and bed light continues to stay on and drains the battery. It's not the door latch. Any ideas?! i'm going to crazy trying to get this truck back on the road!
THANK YOU!
Andrew
Old Dec 30, 2006 | 03:14 PM
lees99f150's Avatar
a 92 has the push button switches in the door jamb. maybe one is broken or shorted.
Old Dec 30, 2006 | 03:50 PM
atsirois's Avatar
The only button is on the drivers side door, When Push it in, the light stays on, yet when the keys are in the ignition buzzing, that will go on and off with the button. So I'm pretty sure that the door button is OK. I don't know if there is a relay or something that I don't know of?
Thank you for your response.
andrew
Old Dec 30, 2006 | 05:35 PM
Steve83's Avatar
There's no relay unless you have anti-theft &/or RKE. Twist the headlight **** out of the "dome force" position. You'll feel the click. As you keep turning it, you'll dim the cluster & dash illumination, so don't go too far until night when you can see the effect.
Old Jan 1, 2007 | 09:56 PM
atsirois's Avatar
what's that suppose to do?
