Air Bag Code 27 00 F150
Old 10-30-2006, 08:50 PM
Steve Bayne's Avatar
Arrow Air Bag Code 27 00 F150
Hey guys I bought a used truck and the air bag light came on a few days later.
It was flashing code 27. After doing some checking the problem turned out to be the bulb was burned out in the passanger bag switch "in the dash."
I replaced to bulb and the code went away.
If you get this code flashing in the instrument cluster, check to see if your bulb is coming on at the passanger disable switch when you trun the key on if not replace it. It might solve your problem as well.
Thanks. AFordMan66
Quick Reply: Air Bag Code 27 00 F150
