Aurometer Dash Replacement
Old Sep 11, 2006 | 11:04 PM
fs_ar's Avatar
Has anyone installed this item?
http://www.autometer.com/cat_gaugede...gid=3379&sid=5
I know the stock guages are little better than idiot lights, but this looks pretty neat! What I was wondering if it used the stock senders and was a plug in item. I seen prices on it around $525.
Steve
Old Sep 12, 2006 | 01:44 AM
cskrmetti's Avatar
It looks pretty good but for $500+, wow thats pretty steep.
Old Sep 12, 2006 | 11:39 AM
Fire604's Avatar
It is plug-and-play using the existing sensors. I have one on order and will post an opinion once installed.
Old Sep 12, 2006 | 01:02 PM
fs_ar's Avatar
Great! If it turns out good I will do one myself. Is this item for 1997 and later? Or just the 2004 and later?
Never mind. Just seen what truck you have. Duhhhhh BTW what did you get it ofr cost wise?
Old Sep 15, 2006 | 04:34 PM
Fire604's Avatar
It should be arriving today and I got it off eBay new for less than $238 to my door. Do a search on eBay - there are a couple on there.
Old Sep 15, 2006 | 10:26 PM
fs_ar's Avatar
Great!
Old Sep 17, 2006 | 09:39 PM
Fire604's Avatar
I installed them tonight and they look awesome. Pics to follow...
Old Sep 17, 2006 | 10:36 PM
fs_ar's Avatar
Can you tell a difference in accuracy?
Old Sep 17, 2006 | 10:59 PM
Fire604's Avatar
Hard to say. I only ran the truck enough to make sure they worked. After running up and down the road a bit I should know more.
Old Sep 20, 2006 | 12:25 PM
jeremyhass's Avatar
yeah i`m bidding on one right now for my 2003 fx4 screw, so does it have all the idiot lights like the factory one ?? and do you have any pictures of it installed??
Old Sep 20, 2006 | 01:10 PM
fs_ar's Avatar
I won one the other night. Waiting for it to come in and also ordered a Trans Temp Temp. Am looking for a Steering Pod to install it in and do it all at once.
I'm waiting for the pics also.
Old Sep 20, 2006 | 01:17 PM
jeremyhass's Avatar
yeah thats what i plan on doing is getting the dual pod for a trans and mechancial oil press. lunar series to match the new dash gauges but i also have the edge montior and was wondering if anyone had put a dual pod on the a-pillar with the edge already mounted in it own pod by the the a-pillar
Old Sep 20, 2006 | 05:05 PM
fs_ar's Avatar
yeah thats what i plan on doing is getting the dual pod for a trans and mechanical oil press. lunar series to match the new dash gauges but i also have the edge monitor and was wondering if anyone had put a dual pod on the a-pillar with the edge already mounted in it own pod by the the a-pillar
I figure the electric oil in the cluster will be good enough for me, but I am ordering the steering pod so everything will be right there. I had a pillar pod with my last truck and found myself always looking over there.
Maybe FIRE604 can answer one question I have though. The Odometer is in the cluster I believe. Does it set back to zero? Is there a way to get the mileage put in there. (I would not think there is or every used car dealer out there would be using it! )
Steve
Old Sep 20, 2006 | 05:33 PM
jeremyhass's Avatar
from what i got that it retains what your mileage is now so it makes me think that the computer tells the cluster how many miles are on the truck??
Old Sep 20, 2006 | 07:56 PM
cskrmetti's Avatar
I don't understand how this can be plug and play but other Ford clusters (FX4, Lariat, King Ranch) have to be programed to work in a different trim level truck.
