power distribution block #24 fuse
on a 99' it would go to Heated oxygen sensor #12 and #22. Also to 4R70W transmission Internal Solenoids. It just supplies 12V to these. I would guess the heater in sensor's is shorted or an internal trans solenoid is shorted. I would guess the oxy sensor. You might try unplugging the sensor's. To say more we would need engine and truck year.
on
With both 12 & 22 disco, you can get a CEL.
11 & 21 are the front ones, 12 & 22 are the 2nd set, which just check that 11 & 21 are doing their job. 11 & 21 are the ones that are used for close loop flow control, if my memory is working correctly ( which is might not be after deling with the amatures at airport today ).
I will try to find the closed loop flow control write up, and post it back here.
on
Originally Posted by gonecrazy
what is a cel?
O2 sensors harnesses have a nasty habit of getting onto exhaust components, melting the insulation, and shorting important stuff to ground. Oh, on these trucks, it can blow BJB F24 which kills the power to the PCM. Nice going Ford! At least it doesn't burn the truck to the ground....
The upstream O2 sensors (11 & 21) are for fuel trim control, the downstream O2 sensors (12 & 22) are there to monitor catalytic converter performance only.
Inspect each sensor harness for melting. If no visible evidence is found, plug one sensor back in at a time until you find the one that blows the fuse. Replace that sensor and the fuse.
Your engine will run with no O2 sensors connected. However, it will be running pig-rich with the upstreams disconnected which will kill your fuel economy and risks damage to the cats from fuel loading if left that way for very long. If you disconnect the downstreams only, the engine will run correctly but that light on your dash will be on.
Steve
