Headlight Problem
Old Jul 12, 2006 | 10:49 PM
nigdonht's Avatar
Headlight Problem
I just wired up a sub and an amp to my aftermarket h/u this afternoon, and had to take out most of my dash, when I plugged everything back in, my low beams didn't work, everything else did, except for my low beams, so I had to drive around tonight with my high beams on. The truck is a 00 F-150 4x2 XLT. Also sometimes when my steering wheel locks it is next to impossible to turn the ignition, and other times, it is fine. Thanks
Old Jul 12, 2006 | 11:20 PM
ronkartz's Avatar
Steeering Wheel Lock
Depending on how far you have the wheel turned, you may need to turn the wheel further in that direction and it unlock the ignition, as far as the lights, I would start with the fuses.
Old Jul 13, 2006 | 10:41 AM
nigdonht's Avatar
Which fuse is the headlights hooked up to?
Old Jul 13, 2006 | 10:54 PM
nigdonht's Avatar
Checked all the fuses, and one of them must've not ben plugged in good, got the problem fixed.
