brake light wont work
Old May 24, 2006 | 06:58 PM
trow56's Avatar
The 3rd brake light is the only one that will come on the fuses are ok and I cont find any broken wires the turn signels flash like mad when I turn them on any help would be great
Old May 25, 2006 | 09:53 AM
SSCULLY's Avatar
Some specs on your truck please...
Year
Body style ( flair side, step side, etc )
Trim Level ( XL, XLT, Lariat )
Cab type ( std, SCab, SCrew )
Old May 25, 2006 | 11:37 AM
trow56's Avatar
2003 screw xlt
Old May 25, 2006 | 02:56 PM
SSCULLY's Avatar
1. Dumb question..have you tried changing the bulbs ?
2. Have you used a meter in the S/T/T socket, to see if you have power with the brakes on ?
2.1. At the same time, check the L & R Stop / turn circuits in the 4 pin trailer tow adapter with a meter.
The turn signals flashing real fast just clicked with me, that indicates that the flasher circuit cannot see the brake / turn signal element in the circuit.
These 3 things will help with pointing to what is going on.
Additional question :
4. I am guessing the truck will shift out of park, am I correct ?
4.1. This is part of the function for the BOO ( Brake On / Off ) switch, to get the shift interlock to release.
Old May 25, 2006 | 10:00 PM
projectSHO89's Avatar
I'd be expecting the MFS or its connector to be the fault. It usually is if the BOO is working (3rd light works).
By 2000, the shift interlock was moved to a separate section of the BOO switch and isn't power by the same circuit.
Do the front turn signals work?
Damn, don't have a 2003 EVTM yet. Been downloading the DVD for a month - 5.5 gig on a slooooow circuit. Almost there....
Steve
Old May 30, 2006 | 09:06 AM
DANSTER302's Avatar
help!!! i have the same problem on a 2000 f150 flare side xlt.
the turn signals work ok, running lites ok, 3rd brk lite on.
fuses good, bulbs good. what is the MFS ?????? vwhere is the MFS?????
Old May 30, 2006 | 09:10 AM
MFS= Multi-Functions switch.
Turn signals, 4-way, wipers, etc on your column.
Steve
Old May 30, 2006 | 10:04 AM
DANSTER302's Avatar
any hints on testing? procedure, tools... i can handle mechanical stuff. electrical eats my lunch
Old May 30, 2006 | 11:10 AM
Remove the column shroud and inspect/reseat the connectors. Several user have reported pushed pins on these connectors. Look for discoloration of any pins indicative of heat buildup. Clean or replace any suspect pins.
Steve
Old May 30, 2006 | 11:48 AM
DANSTER302's Avatar
thank you, thank you thank you... will work on it tonight and will update as soon as i know something
