this is gonna sound stupid
I know this is gonna sound stupid,, but i currently had a dash light go out on me. So i proceeded to remove the dash so i could disconnect the odometer and change the buld. Unfortunatly i can only get the gauge panel to come out far enough to get the tips of my fingers behind it.. I tried tugging on the odometer cable to see if i could get enough slack to no avail... any ideas or suggestions??????
You might want to mention what kind of vehicle you are working on, usually, you release the clip from the speedometer before you remove the cluster.
thnks
thanks I am aware i have to remove the od clip before the cluster,, thats the problem ,, not enough clearence to get to it`... as for what type of vehicle --it's an f-150 hence the reason i posted my ? on a f-150 forum. as for your suggestion lees, thank-you .. i will give it a shot,, your suggestion is much appreciated.
I apologize momalle1 for my rudness
The trans. selector cable is prob. keeping you from access to the back side. The cable is really short. once you get it uncliped you will have much more room to reach behind the panel and unclip the speedo cable.
