Driver side injectors not working
Old Mar 26, 2006 | 06:08 PM
charkly's Avatar
what do you guys think
the fuel injectors on the drivers side are not working, i put a test light on the passenger side fuel injectors and the light comes on and when i try the drivers side injectors the test light does not light up
then i pull the spark plug wires off the drivers lide theres spark but no change in way truck runs, no added hessitation or nothing
its a 1997 f150 6cyl
can sum people help me out please
Old Mar 26, 2006 | 06:31 PM
98Lariet4x4's Avatar
If none of the drivers side injectors are working, only one of 2 things could be wrong:
1. The wiring harness is rotted, cut, burned through, etc, and the firing pulse is not getting to the injectors.
2. Fried PCM.
I check and recheck, and then check some more to ensure all injectors fail to fire before I would go any further. There's an item at AA/AZ called a 'noid light' that's made specifically for testing injector pulses. Costs about $5. Just ensure it's the right one for your year and engine configuration. Then I'd start tracing out the harness. Good luck, and feel free to ask any and all questions.
