2004 wont turnover / start PLEASE help
Old Feb 8, 2006 | 01:02 AM
victor26086's Avatar
hey guys, i have a huge problem. well first i was installing my remote start alarm, about half way everything was fine. just as i got finished i tried to start and nothing. after struggling with it i desided to pull it out. still will not start.
Other problems: shows no fuel, fuel pump shound off, dome lights and chime do not work and the stereo turns on but there is no sound and it stays on even when key is removed and door is open.
when i turn on the headlights and try to start it it wont do anything not even try to start and message display says "low fule and check gauges" PLEASE HELP ME
Old Feb 8, 2006 | 08:09 AM
GIJoeCam's Avatar
Sounds like a dead battery. Did you try jump-starting it?
Old Feb 8, 2006 | 08:09 PM
battery is fine
battery is fine.... today i called road side to pick up truck, i had the emergency brake on so i released it... i gave it a last shot to try to turn on the truck... guess what... it turned on............
well it turns on but everything else is still wrong... pluse the truck turned off after drivng it for a while...it seemed as it raned out of gas, so i when to gas station and dumpped some gas on the truck and message board still showed "low fuel"...hum...well not it wont start again...dealership thinks the fuse box might be bad. thanks for the suggestion
Old Feb 9, 2006 | 11:11 AM
Supergrover1961's Avatar
I'm having a similar problem with my 2004. Last week it wouldn't start after sitting for 4 hours. Not even enough juice to use keyless entry. Took it to the dealer and they said the battery was fine and the electrical system checked out. Well, one week later, I left work last night and no battery again. I didn't leave any dome lights on, etc.. As soon as I jumped it, it was fine. I am getting moisture in the backup lights - Ford says this is not a problem...??? It's in the shop now. If anyone has any insight, it would be greatly appreciated.
Old Feb 9, 2006 | 11:39 AM
GIJoeCam's Avatar
There's a TSB for the moisture in the taillights. Simple fix. The dealership should take care of it. It didn't cause your no-start problem.
Your problem sounds like aeither a bad connection on the battery, bad ground connection to the frame, or a bad power-saver relay that's not waking up when it's supposed to. A few minutes with a DMM when it won't start should have the problem narrowed down pretty quick.
Intermittent gremlins like that are difficult to troubleshoot, especially via the 'net.
-Joe
Old Feb 11, 2006 | 01:08 AM
i called the dealership today and they said that the fuse box that they ordered to replace the one that is on right now was defective so they have to order another any one other have any ideas to what it might be? does it sound like they are right?
Old Feb 11, 2006 | 01:17 AM
Corbin1357's Avatar
yea sounds like a bad lead! make a mixture of 1/3 baking soda and 2/3 water and pour over battery leads, or steel wire brush to clean leads, I had the same prob on my old truck and this worked great!!
Old Feb 16, 2006 | 12:36 AM
got my truck back... well it turned out to be a grey plug that is by the drivers kik panel below the green one, it was slightly unpluged..... dealer charged ford warranty almost 1000 dollars for that....what a rip off
Old Feb 16, 2006 | 01:24 AM
norcatalyst126's Avatar
HMMMM....I have had problems with my truck not starting and its extremely intermittent. I wonder if that could be the problem, the grey plug. Also, there are times that I can't arm my alarm but I'm not sure if thats related to the battery in my truck or the battery in my fob. Question for those with remote start with an '04 and up SCREW, did you have to have a key hidden in the truck so the alarm picks up electronic key signal or did you get the right alarm? Did that make sense? Sorry a little off topic.
