Old Apr 13, 2015, 12:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Is your 'door ajar' or 'dome light' staying on? Forum members suggest various methods that they fixed their issue. The methods include:
          Read the full discussion below to find out the preferred method.
          Print Wikipost
          If your "door ajar" or "dome light" is staying on, Read this.
          Old Feb 11, 2009 | 12:55 PM
            #106
          sambo8807's Avatar
          Question Will this trick work for a navigator?
          will this work on a 1998 navigator also
          Old Mar 6, 2009 | 08:00 AM
            #107
          Foe's Avatar
          Foe
          QUOTE=lees99f150;1642829] If the light is on and the doors are shut then spray some WD40 in to the latch. The door switch is probably stuck. QUOTE]
          Worked like a charm! Thanks!!!
          Old Mar 19, 2009 | 05:35 PM
            #108
          mikelwars's Avatar
          domelight and all inside lights
          I have a 2002 Screw but on mine the door ajar light only comes on when you realy have one of the doors open. The dome light and all the inside lights will stay on all the time and the radio turns off when I put it into reverse or drive.
          Thanks Kev.
          Old Mar 29, 2009 | 03:25 AM
            #109
          freekyFX4's Avatar
          Thanks! My daughter's 2003 EB Explorer is doing this intermittently. I will try this fix tomorrow.
          Old Apr 17, 2009 | 07:42 PM
            #110
          frangr3's Avatar
          Door ajar light on
          Thanks for the tip. I sprayed all four doors and the door ajar light and dome light went out.
          Thanks again.
          Old Apr 27, 2009 | 01:29 PM
            #111
          mikelwars's Avatar
          Originally Posted by mikelwars
          I have a 2002 Screw but on mine the door ajar light only comes on when you really have one of the doors open. The dome light and all the inside lights will stay on all the time and the radio turns off when I put it into reverse or drive.
          Thanks Kev.
          New GEM module and glass. I had a leak.
          Kev.
          Old May 7, 2009 | 11:07 PM
            #112
          dongetmoney's Avatar
          This really works!!!!!!!!!!!!
          I was so frustraded. the dome light would have stayed on all night.
          i sprayed dw40 no more dome light.
          Old May 9, 2009 | 01:22 AM
            #113
          whitty's Avatar
          So has anyone figured out why this still happens when I take BOTH switches OUT of each door, so there is no "stuck" switch, and is there a wire that I can cut to make it stop that annoying BEEP! I've already pulled the GEM out and there is no evidence of a leaky windshield (I had read elsewhere where this was a problem "fouling" the GEM module causing weird things to happen. This is very close to becoming a deal breaker.
          Old May 27, 2009 | 06:36 PM
            #114
          ninja11zx's Avatar
          ok,i just noticed last weekend my dome light isn't coming on when i open the door and the radio and headlights stay on when i turn off the truck and open the door. also there is no buzzer letting you know the keys are still in the ignition. radio and headlights go out after a couple minutes. this is a 2004 f150. dome light wont work on any of the 4 doors. i cant find a fuse for the dome, but it works with the dimmer switch. could the door switches also cause this? thanks
          Old Jun 4, 2009 | 07:34 PM
            #115
          nonwoven29's Avatar
          This worked on my buddys 99 f-150 Thanks a lot.
          Old Jun 27, 2009 | 06:10 PM
            #116
          FX41's Avatar
          Ahhhh.....so nice. Great fix!
          Old Sep 21, 2009 | 03:33 PM
            #117
          RMT150's Avatar
          i have seen the door out of ajustment cause that parblem aswell just loosen the striker and push it back
          Old Sep 23, 2009 | 01:05 AM
            #118
          RMT150's Avatar
          with the sun roof the drains go down the A piller to the fire wall. the fitting at the fire wall gets cluged and causes the water to come out of the drain. remove the fitting and drill it out and the problem wont come back again.
          Old Sep 23, 2009 | 01:08 AM
            #119
          RMT150's Avatar
          o i forgot the grains could of came off at the sun roof as well
          Old Sep 23, 2009 | 03:37 PM
            #120
          Mr Clean's Avatar
          Hi everyone I am new here. First post- thanks Lee ! That is what I have been looking for. I have talked to many F150 owners in my area and all think I am joking about the lights. Thought I was only one having this problem. Mine also will not let you lock or unlock doors from inside or outside by entering code.Only way to lock is with remote keyfob.
