Old Apr 13, 2015, 12:22 PM
How-Tos on this Topic
Last edit by: IB Advertising
Is your 'door ajar' or 'dome light' staying on? Forum members suggest various methods that they fixed their issue. The methods include:
          Read the full discussion below to find out the preferred method.
          Print Wikipost
          If your "door ajar" or "dome light" is staying on, Read this.
          Old Mar 12, 2006 | 04:04 PM
            #31
          chester8420's Avatar
          Originally Posted by jpgillespieusa
          I used the wd-40 trick and low and behold the light went out. It was driving me nuts...
          Now I notice that the light will stay on ocasionally until I turn the key to the on position then it goes out.
          Any ideas?
          Jimmy
          Sounds kinda like a problem I had once. I had an accessory that was grounding back into the fuse panel. It was doing screwy little things like that and I couldn't figure out what the heck was going on!
          Old Mar 15, 2006 | 11:59 AM
            #32
          xibbumbero's Avatar
          Originally Posted by Dog'em
          I had the same issues with my 98 scab, tried the WD40 along with everything else I could get my hands on with no luck. Finally ended up replacing the $10 relay in the fuse box and have not had a problem since.
          Which relay switch? X
          Old Mar 15, 2006 | 03:37 PM
            #33
          Dog'em's Avatar
          It's the relay in the main fuse box that controls the interior lights, check your owners manual. If it's bad and needs replaced, if you go to Ford and give them the number it will show that the relay is discontinued with no replacement. I used the relay that they recommend for the A/C and have not had any problems since.
          Old Mar 15, 2006 | 04:09 PM
            #34
          xibbumbero's Avatar
          Dog'em,Thanx . X
          Old Mar 18, 2006 | 12:46 AM
            #35
          brino's Avatar
          I have a similar problem on my '95, but my light will just come on after a while. I had to disconnect the plug to the brain box under the dash.
          What would cause it to just come on while the doors are closed. The other day the lights were off and about 1 hour later they were on?????????
          Old Mar 19, 2006 | 03:15 AM
            #36
          JgGravy's Avatar
          Had this problem the FIRST day i got the truck, and now it's all fixed thanks to good old WD-40. Ended up leaving the vehicle running so my battery didn't die on me and burning up a good 1/4 tank of gas.
          Now i havn't had the problem for 4 days and i know how to fix it in the future.
          Old Apr 5, 2006 | 04:16 PM
            #37
          Kiamichiman's Avatar
          Smile A million thanks
          The WD-40 trick worked for me. Thank You.
          Old Apr 5, 2006 | 04:25 PM
            #38
          speedraisor's Avatar
          if the WD-40 doesn't work replace the door ajar switch itsekf, easy to do and costs about 14 dollars
          Old May 9, 2006 | 10:13 AM
            #39
          lonewolf211984's Avatar
          for better longer lasting results instead of using WD-40 there is a product on the market which is a lubricant (safe with electronics also I use it in my gaming cpu @ home) WD-40 is a rust remover not a lubricant though most of us (myself included) use it as 1. I will edit this when I get home and find that can of spray. Good God why are the hands on the clock moving so slow now?
          Old Jun 2, 2006 | 12:35 AM
            #40
          StirCrazy's Avatar
          I agree totally, The problem with WD40 is it attracts dust and gums up fast, so you will be doing this once a year or more, what I use is an electrical contact cleaner to unjam the switch, then use a silicone based lube spray. I did this once 5 years ago on both my F150 and the wife's Taurus, where my buddy does it every year because he is to cheep to buy anything but WD40
          Steve
          Old Sep 30, 2006 | 02:16 AM
            #41
          chrism9232's Avatar
          my 96 ford taurus is sticking anyone know if this will work
          Old Sep 30, 2006 | 02:18 AM
            #42
          chrism9232's Avatar
          unplug the relay for the dome light that is whit did on my 96 taurus
          Old Oct 14, 2006 | 08:39 PM
            #43
          Tindjin's Avatar
          Just gotta say that I love this board. I know I don't have many posts or been a member a long time but stuff like this post has saved me hundreds of dollars so I happily clink on links from here looking for new gear..
          Day before my appointment to have this issue fixed I stumbled across this board 4 months ago, ran out to my truck carrying my trusty can of WD40 and 10 minutes later was canceling the appointment. I love penny tech!
          Old Oct 16, 2006 | 03:08 PM
            #44
          waterman308's Avatar
          works on Expy's too
          Used wd40 followed by silicon spray for reasons cited above. Even did the hatch back latch (say that 3x fast!)
          Old Nov 8, 2006 | 09:59 PM
            #45
          phildacf150's Avatar
          I had this on my 97 F150 and my friends 99 f150. I bought the part, it is a pin switch that sits upside down above the latch. Cost about $12 for the part and then you just take off the door panel, unhook the handle latch rods and then unhook the switch wire connector, unscrew the 3 bolts holding the latch to the door, take out the latch, replace the pin switch then reverse these directions to put back together. The pin switch gets gummed up and needs to be replaced, or you can just fill your doors with WD-40. my $0.02
