Headlamp Turn off fuse
Old Dec 28, 2004 | 11:23 PM
greencrew's Avatar
My fuse keep blowing out. It's a 5amp fuse for the headlamp turnoff and over drive switch. I'm getting good at replacing it, but would like to know if I can fix the problem, or if I should just go to a larger amp fuse.
The truck is an 01 Lariat Screw 4x4.
Old Dec 28, 2004 | 11:40 PM
lees99f150's Avatar
try doing a search on the overdrive switch
I think they have problems with the wires in the shifter lever rubbing and shorting.
Old Dec 28, 2004 | 11:59 PM
greencrew's Avatar
I did a search, and found those threads. Thanks for the quick answer.
