remote starts
Old Dec 17, 2004 | 09:22 AM
STUACE's Avatar
remote starts
Just bought an 04' F-150 5.4L. Im happy with it so far. I went to the dealership and asked about remote start kits. The guy said it would be about $250 to purchase & $250 to install. Wow! Ive read some comments about aftermarket kits and I am torn. I dont like the idea about leaving a key attatched to it so it will work. Or the trouble of paying someone else to install it. Ive also heard they are somewhat tricky.
It almost sounds like I need to bite the bullet here and have the dealership do it. Has anyone gone this route? What was the cost? Is there a good alternative?
stu
Old Dec 17, 2004 | 12:33 PM
drteater's Avatar
I just installed a cheapo depot alarm,keyless entry, remote start system with a PATS bypass kit. The total with the kit was 140 and I installed it myself. If you're comfortable with electronics I'd say go for it but purchase the wiring harness adapter from Bulldog security it's worth the extra $13. You can make all your major power connections out of the truck then just plug this in to your ignition wiring harness. You need 2 keys to program the bypass module but you don't need to leave a key in the truck. The programming is described right in the Owners Manual. Good Luck and I'm no professional just a hobbiest but I felt it was a pretty easy install.
Old Dec 17, 2004 | 02:48 PM
SSCULLY's Avatar
I got the silver remote start kit from www.oemfordparts.com. It was south of 200.00 as I recall, including the PATS bypass. Install is not bad at all, if you are good ith digging around with the electronics. There are a few posts here that have some info on it, and the gotcha's found ( that is where I got the info from ).
Good luck.
Old Dec 17, 2004 | 04:57 PM
arrbilly's Avatar
you should be able to get a good aftermarket unit for around $250 installed at a reputable security dealer. Probably about $100 more to add an alarm with it...
Dealer installed stuff is always way over priced.
Old Dec 18, 2004 | 01:02 AM
je3169's Avatar
I just bought and installed the ford power code gold system RKE,VSS,RMST for $204.00 from fordpartsonline.com you need to get the pats box $31.00 installed it myself not hard at all if you get it from FPO they will send you the install book in a PDF file it has everything you need to know about installing the system into your truck.
John
Old Dec 18, 2004 | 03:56 PM
STUACE's Avatar
The parts guys at the dealership here must be high. Theyre telling me it takes 4-5 hours of labor to put this thing in. They also keep giving me different prices and part numbers that dont work in any search. I tried to look it up on fordpartsonline.com but couldnt find it. It seems to me that since its ford part it should almost plug in to the existing harness.
Do you have the part#? What is rke, vss, rest?
Old Dec 19, 2004 | 03:27 PM
arrbilly's Avatar
the ford remote start and their security systems are not factory ford parts. They are made by one of the after market security manufacturers and have the ford decal stuck on it...
Old Dec 20, 2004 | 04:28 PM
je3169's Avatar
the part # 2W7Z-19G364-AA is for the
RKE =remotekeyless entry
VSS =vehicle securty system
RMST=remote start
$204 and change at FPO
it is made by code alarm for ford
took me about 2 hrs depends on you skill level i did alot of alarm and radio installs in my day.
John
Old Jan 17, 2005 | 05:41 AM
kcap 85's Avatar
go to my gallery I put a diagram up of the anti theft (pats) system will add starting system in a bit gotta convert from pdf to jpeg
Old Jan 17, 2005 | 10:38 AM
TonyPTX's Avatar
RMST=remote start
John
Wonder where you got such an awesome list of info
Tony
Old Jan 24, 2005 | 01:08 AM
cj797's Avatar
I put in a cheapie AutoCommand I bought off eBay for around 60.00. Weird tho, in my 97 XL I didn't need the PATS bypass. I guess that was for the more of the XLT and above line.
As far as the remote starter, it has a few things to be desired, but I installed mine in about 2 hours, and it works just fine. I did solder all connections, not just the wrap and tape as I have seen many of the instructional videos.
CJ
Old Feb 16, 2005 | 06:56 PM
19(F150)99's Avatar
i just installed a crimestopper remote start/alarm and what do i need to be able to use the remote start with out having the key in, is their a bypass it or what?
Old Feb 17, 2005 | 12:11 AM
je3169's Avatar
Error
Old Feb 17, 2005 | 12:17 AM
je3169's Avatar
Tony
I wonder
John
