battery going dead????
Old Nov 18, 2004 | 10:08 PM
RMartin1967's Avatar
Question battery going dead????
every time i turn on or off my switch, i hear a thump over mt speakers. and if my truck sits for longer than 24 hours, i have to charge my battery. what is my peoblem, i have a 97 150 with a 4.6, please help
Old Nov 19, 2004 | 07:54 AM
projectSHO89's Avatar
Check for a parasitic power drain in excess of a 100 mA. Glovebox lights are good for this. Also, make certain that all components of your audio system (if an add-on) are being switch off when the iignition switch is turned off.
If no power drain is found, assume your battery is failing.
Steve
Old Nov 19, 2004 | 09:10 AM
Mattmanyam's Avatar
Do you have an aftermarket amp installed? The "thump" indicates to me that the amp is wired such that it stays on all the time, instead of turning on and off with the head unit...Does the "thump" go away if you cycle the ignition with the radio turned off?
Old Nov 20, 2004 | 05:09 PM
no after market amp, but today my battery is dead
