Brake warning switch?
Old Nov 16, 2004 | 09:42 PM
BluestOval's Avatar
Registered User
Hi...
I've got a 2002 SCrew... on the front of the brake master cylinder there is an electrical plug going into some sort of switch... anyone know what that switch does? Is it a brake fluid and/or pressure warning switch?
Thanks,
Levi
Old Nov 16, 2004 | 10:53 PM
Tbird69's Avatar
It's a pressure differential switch. Should there be a failure in one half of the system, the switch moves and triggers the dummy light on the dash.
Old Nov 16, 2004 | 10:58 PM
BluestOval's Avatar
Registered User
Thanks, I appreciate the info.
Old Nov 16, 2004 | 11:22 PM
lees99f150's Avatar
the switch on the front of the master cylinder is for the cruise control.
Old Nov 17, 2004 | 08:10 AM
projectSHO89's Avatar
There should be a fluid level switch (often in the cap) and the Cruise Deactivator switch mounted on the master cylinder.
The Deactivator switch removes power from the cruise module in the event of high brake pedal effort. It is a redundant safety device that is there to disconnect the cruise in the event that the brake (or clutch interlock switch for a manual transmission) light switch circuit fails.
Steve
