Standed by Ford Electronics again
Old Nov 15, 2004 | 08:10 PM
GregB's Avatar
AOD tranny problems
My second truck is a 1992 1/2 ton F-150, with a 302 automatic, and AOD transmission. I was wondering if someone could tell me why I have lost just the drive and overdrive range in my transmission. All other ranges work (reverse, 1st, 2nd, neutral). In the past, I have experienced this problem in another truck, which turned out to be the governor. I was told it was a bad drive band in this one, which I hope to not have to pull the tranny for. Anyone's advice or help would greatly be appreciated.
Old Nov 15, 2004 | 11:29 PM
Tbird69's Avatar
Locate the ignition module and if you can, remove it and get it tested. A bad module will cause your no start.
Old Nov 17, 2004 | 08:12 AM
projectSHO89's Avatar
You really need to identify which subsystem is malfunctioning: Fuel delivery, Spark (ignition), or air.
Then you will know where to focus your efforts.
Steve
