Speedo smoothness problem
Old May 22, 2004 | 01:12 PM
edgex's Avatar
Okay I recently removed my needles to do some custom work to my cluster and my speedo doesn’t seem as smooth as it was before. Every once and a while it will stick.
Yes I did check the clearance between the needle and the faceplate and there is plenty of space. Anyone had this problem before? Thanks
2000 4.6 Lariat 150
Old May 23, 2004 | 10:36 AM
edgex's Avatar
Okay, I did the TEST mode and my gauge sweep is fine, but when I go to the EE mode it says FAIL. Now according to the chart for the test mode it says to replace the instrument cluster. True or nothing to worry about. Could this be what is affecting the analog gauge for the speed?
