Keyless Entry Question
Old Apr 18, 2004 | 12:54 PM
BarryBum's Avatar
My keyless entry remote for my 97 F-150 was dropped and broken recently, I found one on Ebay that matched my FCC number and the fellow said it would work. I bought it, but not received it yet. When I do get it, how do I program it to work on my truck?
Old Apr 18, 2004 | 01:52 PM
Mr_Bentwrench's Avatar
cycle the key from off to on 8 times or until the doorlocks cycle stop in the on position. then push a button on transmitter doorlocks should cycle again then turn truck off and everything should be workin.
Old Apr 18, 2004 | 03:09 PM
SSCULLY's Avatar
Make sure you program all the remotes you want to use at that time.
The keyless entry does not work like programming additional PATs keys, where it adds one to the system. Programming keyless entry remotes is a overwrite all previous with the ones you just did, so if you program in the new one, all the others that did work in the past are gone.
Jeff has a post at the bottom of the page for this :
Originally posted by kidtriton
remotes= make sure you do all the ones you want to work at the same time. Cycle the key from off to run eight times, ending in run the eighth time. The locks should cycle. Press any button on tramsmitter, locks should cycle. Press any button on second, third, fourth.... trans., locks should cycle. Turn key to off position. All transmitters you just programmed should work, all previous transmitters not done that time will no longer work.
Full thread :
https://www.f150online.com/forums/sh...threadid=83829
Old Dec 1, 2004 | 06:00 PM
nakidgun's Avatar
Try this site for remote programming instructions. I bought a remote from them and they sent instructions along with it.remote programming instructions
