Auto-lamps on 99 Lariat
I have Auto-lamps on my 99 Lariat. The lights come on just fine when it gets dark outside. The problem Im having is that they do not want to trun off. I waited one time for almost 20min then they went off. I have the adjustment screw on the controller that allows you to shorten or lengthen the ammount of time the lamp remain lit after shutting off the truck and have tried to adjust it but it still stays on for over 15 min. Thanks for any help.
Humm I will check but I believe that the interior lights would be on too. But they go off. I never knew that there was a protection system for the battery thats good to know. Does it just shut everything down when it starts to die?? Thanks for your input.
I'm not to sure. If I had to guess (and I know that doesn't help you) I would think that it might be a seperate relay timer. When mine kick off I can hear a loud CLICK under the center of the dash.
OK I just read another post and just maybe it IS in the switch
https://www.f150online.com/forums/sh...hreadid=136676
