Battery Light
Old Sep 23, 2003 | 01:26 AM
sleepycreek's Avatar
Question Battery Light
Hello,
I have a 99' F150 5.4L V8. 72,000 miles. I have noticed the battery light staying on recently. I took the altenator out and it was tested and found to be shortening out the test system, so I replaced the altenator and the 4 year old battery.
After driving about 60 miles now, the light is STILL ON and I notice just a little difference in the idle speed; it wants to idle a little faster.
Any suggestions?
Thank you
Old Sep 23, 2003 | 01:57 AM
Pestco1's Avatar
The idle could be that the truck learned a new setup from when you had the battery out. I wonder if you have damage to the charging circuit. If the alt. shorted the test equipment did it damage something in the truck?? do you also have a gauge??
Old Sep 23, 2003 | 05:53 AM
Thanks Pestco,
I don't have a gauge. I suppose there could be damage in the charging system. The intrument panels voltage gauge seems to maintain full charge as of yet.
Old Sep 23, 2003 | 05:02 PM
Pestco1 thanks again for your help.
You are correct in that the altenator has affected something else. Apparently, a 20 amp fuse was blown somewhere along the way maintaining the glow of the battery light. I am not certain if it blew before or after the installation of the alt. and battery but that was the problem.
