Finished installing switches in overhead console
Old Apr 21, 2003 | 02:05 AM
dcovell's Avatar
And I think they look great! Radio Shack switches (many others have used them on thier trucks) with part number 275-731. The red LED isn't too bright and reminds me if I use my lights during the day that thier still on and sucking down your battery stupid...
Also because this compartment normally holds the garage door opener I placed a few rubber feet above the latch so that it would not more when pressed on. You could still put a small garage door opener in thier if you wanted but this truck hasn't seen the inside of a garage nor will it ever at almost 7 feet tall.
Old Apr 21, 2003 | 02:09 AM
dcovell's Avatar
Oh yea and this is what the switches are powering...
The PIAA driving lights
and the Hella AUX backup lights
Old Apr 21, 2003 | 08:57 AM
Robdude30's Avatar
Thumbs up
Looks good!
Was it much trouble to fish the wires up overhead?
Old Apr 21, 2003 | 10:01 AM
Rockpick's Avatar
Moderator &
Those look really good dcovell!! Nice job.
RP
Old Apr 21, 2003 | 10:53 AM
dcovell's Avatar
I ran some multiple conductor wire and had to drill one hole though the firewall as all my wiring under the hood was on the passenger side. I need 3 conductor for each switch and they can share a common hot with the PIAA relays.
With you own relays you could share a common hot and ground. Then you just have a switched hot back to the relay to power it.
I have disconnects in the compartment in case I need to remove the switches.
The hardest part about running those wires was driling the hole right next to where the computer pokes though the firewall. I had to take down a part of the roof as well but that was not that hard.
Old Apr 21, 2003 | 01:44 PM
Robdude30's Avatar
Thumbs up
Thanks!
Old Apr 22, 2003 | 12:31 PM
svt360's Avatar
looks good,i put mine inside!
Old Feb 18, 2005 | 10:41 PM
bamacpl's Avatar
I did mine like this....I like how you did yours!
Old Feb 19, 2005 | 07:24 AM
jhogan's Avatar
Wow, nice find on the thread, almost 2 years old....
Old Jan 10, 2011 | 01:33 PM
stugraham's Avatar
where did you get the valance for those HUGE lights dude. lemme know cause im looking for a valance like that
Old Jan 10, 2011 | 02:46 PM
SSCULLY's Avatar
That is the PIAA airdam. Not sure if they are still made, I had one on my 2001.
The outside positions hold the PIAA 520 lamps, the inside are PIAA 510 lamps.
