will the gauge cluster from a 97 fit a 95?
So which is it
OR
And by DMV do you mean the dept. Of Motor Vehicles?
If so, so what? is that bad for some reason?
Also is this going to be an easy swap?
Are there any models that will just plug and play so to speak?
1995 and 1997 are completely different cluster shapes and body styles
The '97 F250 and F350 would have the same style cluster
Yeah. The DMV will want to know why your mileage doesn't match up. They'll know when you go for a state inspection.
The cluster from any Ford truck with the same dash as yours will bolt up. The wiring harness may be different.
