No back lights...help please!
Old Feb 23, 2003 | 11:50 AM
rongleaves's Avatar
Yesterday I was driving out of a creek bottom at my deer lease and hit my 7-way on a rock. The wires going to it look okay some looked alittle smashed but not cut. I now don't have any power back there. My hasards don't work, no break lights, no park lights, no reverse lights and my license plate lights are also out. I've got a 7-way test plug with lights on it but none light up when I plug it in. I've checked all the fuses in the cab fuse box and the fuse box under the hood. Any ideas what might be the problem. I'm a little worried here. Thanks for any suggestions.
Ron
Old Feb 24, 2003 | 01:11 PM
flafonman's Avatar
Not sure exactly what happened to it either, but it sounds like you have one heck of a dead short in it now. I wouldn't even bother trying to chase it out.
" YL3Z*13A576*GB " 7pin / 4pin connector and harness
Is the part number for the harness at your local dealership. Follow the existing cable from the back bumper along the driver's side frame rail. A couple of feet in (it may help to lower the spare) is a quick connect. I suppose you could start here first and see it just plain came unplugged when you bottomed out, if it didn't replace the harness with the aforementioned part.
Good luck
Old Feb 24, 2003 | 06:14 PM
rongleaves's Avatar
flafonman - that's exactly what I did yesterday. Dropped the spare tire and began tracing it out. That connector had come unplugged! Simply reconnected and everything worked. Much happier now.
